Sorry Pete
Ah yes- thanks for reminding me why it's better to suck out the old rather than disconnect pipes: potential introduction of air. I did use a syringe and a similar method to what you describe on my 190D about 7 years ago. I forgot that there's a filter in there and hadn't heard about using 2 filters, though that makes sense. Thanks- I'll follow your advice/instructions.
Others have pulled the return line, and had a friend start the car whilst collecting the old fluid, and watching the reservoir doesn't empty completely. I hear that the fluid runs-out at a rate of knots, and find my method sufficiently effective. In any case, it's better than leaving the 20 year old fluid in there. IIRC The PAS should self-bleed most effectively by raising the front so there's no load on the wheels, and twirling the steering lock to lock 10+ times.
He he- so much for self-priming eh?!
Quite
Yes, SVO is known to dislodge some of the crap left behind by Diesel in the fuel tank and system when you first start using it..... Didn't seem to affect the tank strainer though- I never had to get involved with it.
That's a relief. Did you pull-out and clean / renew the tank strainer and o-ring in the w201? I know what's involved in pulling out the tank in the saloon w124; I don't particularly want to do it if it's not necessary. Access to the strainer is far better in the estate.
I had my 190D's wiper suddenly stop on me on the motorway once due to the gearbox mech seizing. Scary stuff!
When that happened a few years ago I bought a NOS part from the 'Bay which I have kept hold of, so I have a nearly new backup, but I would like to keep the original going for as long as poss.
I'm not entirely sure the w201 and the w124 wipers are the same though they might be interchangeable. Don't even ask what they're asking for at the stealers. I have an ebay backup as well.
Thankfully the aerial hole's looking OK and there's only the slightest sign of rust starting inside at the bottom of the O/S rear window. I'm wary that seeing a tiny bit of rust could mean that something more severe is lurking out of sight, but will be investigating and hopefully sorting out. Hadn't heard about the tops of the rear door being a potential rust area- will investigate. Do you mean the hatch or the side doors?
The official MB Club gazette ran a piece this month documenting a repair of the rear n/s cargo window. The cost of that repair would have consigned my 300d to the scrapper. The w124's also seem to go at the forward rear suspension bushes. Rot there can, and has spelled the end for a few forum members' cars.
The tops of the rear side doors are a potential rust area, though not many people check here. Most of the cars I saw suffered from bubbling on the top frame, under the rubber seal.
Yeah, the aerial's been sticking sometimes when retracting. I'll get the meths & lube on it. Hadn't heard about the fuel cap potentially sticking- thanks for the heads up, will sort that too.
IIRC I read that any lube heavier than silicone spray will gum-up the aerial. The fuel filler flap - I've heard of it sticking once. When the guy had pulled up to the pump. Preventative maintenance and all that.
Having seen the pics, yours looks to be in good shape. How many miles and how much was it, if you don't mind me asking? I'll be getting an estate at some point as a workhorse to help with my house move and renovation.
