Gone into my files. For my CLS55, M-B schedule a diff oil change at 10k then every 30k. ATF change scheduled at 1st 40k only then no more. No schedule for S/C oil.
I've done diff every 30k and ATF at 40k and 80k.
Thanks for the info, it's good to know!
Fab thread, just my cuppa tea. OP, is this project for keeping or selling? Just being nosy.
I'll probably end up keeping it, it's never going to be worth much given the mileage. I think it must be one of the best BHP/£ cars.
Great thread!! Re tear boot leak, oull back the left hand boot liner fabric whrre all thr audio units Are housed. In behind there is a big retangular shaped vent with a seal... on the rear quarter panel ..
that fails commonly . They are cheap and relatively easy replace
Thanks for this, I checked it this evening and got the air line around the vent.
I would be Curios to know if your SBC unit is the original one.. ?
I'm sure I saw a receipt for a replacement when the car was relatively new, I need to check up on this.
Thanks for all the interest so far, I thought people would think I was mad.
Latest Fix:
I encountered my first 'Malfunction' which turned out to be self made. An 'SRS Fault Visit Workshop' come on today, a quick scan shows 9243 'The resistance value in the ignition circuit containing component R10/10 (Front passenger side airbag ignition squib) is too high.'
A quick google showed the connector under the seat is a common issue or potentially a connector in the foot well. The back of this seat was held on with a cable tie so I assumed someone had been in here before. I removed this and followed the wire down, all looked ok here. A quick look under the seat revealed the other end of this cable no longer plugged into anything and a similar shaped connector next to it also disconnected. I forgot to take any pictures due to the excitement of a quick fix. Just to note anyone with a similar fault, you need to clear the faults with a computer, ignition cycle will not clear the SRS code. Once connected, everything on the SRS module passed with no faults. I had moved the seat forwards and backwards several times while cleaning and fixing the back seat, it must of caught on the frame! I've outlined the harness and connector in a red box for anyone reading this with the same fault.
£Free cost with computer
Managed to tidy this up much better and replace the two screws at the bottom which holds it in place.
A quick check of the vent to make sure all was dry.
Thanks for reading, will update how the test goes on Friday!
