Talkwrench
Small update, the back end is now done and back together complete with new discs and pads and shoes. I even found the time to clean the back boxes off! They were covered in tar lumps and general filth. I didn't know the OEM boxes were manufactured by Sebring exhausts.
So with the back end sorted it was time to take on the front. It came apart very easily and I opted to remove the stub axle from the car to remove the ball joints.
And out she popped!
I've opted to refit Meyle components throughout and were available the HD variants as they're made to exceed OEM specs and covered by warranty for 4 years, they do tend to attempt to fix common ailments and I've had good succcess with them previously.
New HD lower ball joint, once again the original one was very loose and I could feel some play.
I've fitted a new Meyle HD thrust arm, new inner spring control arm bushing and new ball joints throughout, inner & outer track rod and fresh gaiter (still waiting for the correct track rod end to be supplied!). Shame I couldn't find a part number for the ball joint in the bottom of the strut. I just hope this wasn't contributing to the clunking I could feel over the bumps. I've only done one side as I wasn't too happy about the axle stands being used on the aluminium subframe so used the trolley jack to take most of the weight on the jacking pad and the axle stand propped underneath as a safety. Anyone any suggestions where I can locate the axle stands? I'll need the trolley jack when I get to the engine mounts to lift the engine.
So i will finish torquing the first side in the morning and fitting the new disc and pads then make a start on the other side. Then its just engine and gearbox mounts! Thought I'd save the best till last haha.
I did manage to have a look at the keyless go button to see if I could see what was wrong, i think I found the issue
I managed to straighten the pins without snapping them
And reassemble ready for test, I didn't want to start the car without the front disc fitted I didn't know if the SBC did any start up sequence and was worried it'd fire the pistons out of the caliper
So haven't tested it yet.
And out she popped!
