gary350
- Jan 20, 2004
- Location
- south wales
- slk 230 & slk 350 (sold) Jag XF 2.7 Premium Luxury
gary350 said:gary
Here's another article, with the maker's name:lotusmark2 said:The wife refuses to beleive this picture is not a photo shop special, any one know model numbers or where I can find more info?
As you say, the arch gap differs on those pics as the bus is clearly jacked up to let the car out.Rory said:That's interesting - the height of the car vs the opening didn't seem right, but I can see from the sequence of pictures that the whole bus is jacked up, which isn't so obvious from the single picture in most of the articles.
I wonder if a 129 would fit in thereRory said:Another point is, why show a family of 3 against a 2 seater car?
Totally agree. I wonder if htey are using the car to highlight the space available? The front wheels of the motor caravan, are clearly off the ground.Rory said:That's interesting - the height of the car vs the opening didn't seem right, but I can see from the sequence of pictures that the whole bus is jacked up, which isn't so obvious from the single picture in most of the articles.
It looks like the space that would normally be filled with luggage on a big coach. Prop shaft? If it's RWD and rear engined then prop shaft won't be a problem!glojo said:I can recall pictures of cars fitting into a drive-in rear compartment which surely must be far easier to design. I wonder if the SLK version impedes with the prop shaft?
