miggit
Greetings All, I am a new to this forum and Mercedes ownership...
I have a Range Rover TD6, which has been a eye opener... But as I tow for a living and the Range Rover is eating gearboxes, I have decided to try something different... a ML270CDI Manual..... So far I have found that it pulls like a train and is almost as temperamental as a Range Rover
So far I have suffered a dash full of orange lights.... caused by rain... think it's an ABS sensor issue, the cruise control is intermittent (probably water again) and the door locks have not only started to 'machine gun', the drivers door has also broken the spring, refuses to lock and the button pushes against you when you try to lock it manually
I have been a member of a Range Rover forum for a few years and have not only found it to be very helpful, but also rewarding to help others too. So far I haven't been able to tow with the car as I don't have a tow hitch... although I do have the Mercedes tow hitch receiver and the 13 pin wiring... but no hitch
Early days.... I can see me sticking with a Mercedes, if it performs half as well as I think it will.... First I can do is to the door to lock
