A few updates... on my owning experience
Still not changed my brake discs, but the current ones are good for now. Soon.....
New consumer battery in boot (mid August) has improved my car as some of the features that didn't work are now working, memory seats, soft close (more on that in a minute) dimming rear view mirror.. all now working..
A month ago I went on a trip to a friend and the car got an absolute soaking.. rain on and off for days... when I got home I discovered to my horror the boot was soaking wet.. did all the usual things, removed the boot liner into my house for a few days to dry out . I dried everything I could and put a small portable dehumidifier in the boot.. that pulled about a litre of moisture out.
I appeared to have got away with it.. and thanks to this site and its great contributors I swapped the boot seal for a new one and put the pics here :
R230 Boot Seal Leaks | Bodywork (Thank you RedSpecial the OP)
Have been enjoying the car a great deal, always turning heads with its looks and sound... However.
Yesterday everything seemed to be fine... at a friend's house showing them my car.. roof down all unlocked, when suddenly the soft close on the boot stopped working, after literally 50 previous trouble free uses.. I put it down to experience and drove home, only to find I couldn't open the boot, and the remote fob flashed the indicators, but didn't lock/unlock the doors.
Bugger.
Lots of industrial language uttered... and today I began looking at the issues.
Luckily I followed advice and checked the key worked in the boot lock last week.. so I was able to open the boot with the emergency key.
I still have to lock and unlock the doors boot with the emergency key though.
Checked the Central locking fuses in the bin behind the drivers seat... not blown.
Cannot hear any noises from the pump with mechanics stethoscope..
But... the door unlocks with my keyless key, but the door button doesn't pop up.
No locking happening from dash button or either fobs both of which have new batteries.
New battery in boot is showing 12.5v and left it on the trickle charger all day to be sure.
I checked some fuses in the engine bay too but no blown ones.
I can only deduce that the pump is malfunctioning or broken.
I have read that the impeller can self destruct with no warning and therefore not operate anything..as it cannot generate a vacuum or pressure.
Its been about a month since its soaking, (with no doubt previous ones too judging by the rust on the seal bracket)
and everything has worked flawlessly (once the boot battery was replaced.)
One thing that has not worked since I got the car is the massage/lumbar seats which I believe (someone correct me if I am wrong) is also connected to this pump? but I believe the pump disengages this air circuit when it detects a leak?
Tomorrow I will remove the pump and have a look and see if there is any possibility of fixing it.
If its electronics are water damaged, I may go for a recon one.. I don't fancy a short grand for a new MB one.
I have some questions for the audience who have been here before..
I found a simple pump removal guide? (this guy is excellent)
With the removal of the pump generate a fault code in the car needing an unwanted trip to a dealer?
Is it better to disconnect consumer battery first or just pull the yellow block fuses behind the drivers seat??
I plan to follow this guide and strip the pump myself. to check the impeller.
I would expect it would be a good idea to check the pipes under the seats for splits etc.. as the soft close was working I will not dismantle that until it doesn't work anymore.
Anyone done the seats before? do I need to remove the seats?
Lots to do...
