non stop rain - leaking roof!
NICKYB
wales
230 clk conv
after the full day of rain yesterday my roof started to leak! GREAT!,
Does any one know how much to replace the seals on the clk w208 roof? the water was coming in over the front windows, where the roof meets the a frame.
Im thinking i could fit these myself, but if i want this to work and last should i take it to a specialist?
thanks all.
thanks all.
I can put up some details this eve, you may have to remind me with the first 6 VIN numbers, do it tonight
Check it is all adjusted properly first of all. The windows are a nightmare to set up if you are not experienced
Do a test yourself with a watering can and pinpoint exactly where it is leaking.
i know how to adjust the front windows, but this is leaking pass and drivers side i think its the seals myself.
for peice of mind i think i'll replace the seals, unless there a stupid cost of course.
any one changed these?
Yes and from memory they run down the A pillar too if you are refering to the very top roof seal.
i will try to take a photo later today.
