NTG3 Video input missing (?)
7marantos7
E250 CDI (C207)
Dear all,
I am looking for a video input in my head unit. The car is C207 2012.
In the menu, I have got a 'video aux' option but I cannot find any inputs under my armrest or glove box.
I know that there should be some inputs in the glove box, but there is only an empty hole! (please, see picture attached).
Have you got a diagram of outputs at the back of a unit, please?
Perhaps a cable at the back is missing?
Many thanks and regards.
Martin
I know mine is a completely different generation of car and comand, but in my 2008 w209 the video inputs are actually in the rear of the car behind the trim in the o/s of the boot, certainly not where I would expect.
I found the unit (TV tuner I believe) when replacing a bulb and tested it and it works with anything I’ve tried plugging into it.
looks like that RCA panel is missing...(pic)
where can I buy it?
I would imagine it to be a Mercedes dealer part unless you find one on eBay or the likes.
I would be removing the glovebox if that’s where it’s meant to be, and checking it’s actually wired for it, it could of not been fitted from new.
You might get lucky and find it tucked away, like someone’s been working behind there and forgot to clip in back in place.
I have been thinking about the same thing. I would expect the inputs to be there or the hole to be blinded and no option available in Command.
So it could be pushed in there. ...I put my finger there, but cannot feel anything.
I tried to remove the insert of a glovebox, but I gave up. I need to find an instruction on how to do it :/
Perhaps I should get something like this...(pic) ??
But where to connect it to?
