Also agree that a torque wrench is not the best tool to undo wheel bolts. Even if they were torqued to spec, after a period of time it will often need a fair bit more torque to break them loose and if someone has over tightened them, well then it's really abusing the torque wrench.
I have no trouble at all using the original supplied wrench to undo wheel bolts however tight as you can safely stand on it if necessary. But you can't so easily do that for the locking bolts as if they are tight you have to push the tool into the bolt and apply torque at the same time.
