Although the advert states that tool will fit W204, note it won't fit all models.
Those with the M271 engine need a 27mm socket to undo the oil filter.
That looks rather like the MB original one I got for my M104 engine. We did an oil change last week and it was a delight. We took the air filter off but, on reflection, it wasn't necessary as the tool worked so well.
I found it brand new, by searching the part number (103589020900, I think), on eBay or Leboncoin (France) for about 30€.
can I repeat the question ? I need a tool to remove my oil filter for clk 280 -w209 any link or part number ,went for strap from amazon but did not work
I just use a strap wrench ,which has other uses . As for the correct tourque when re fitting the filter cap I just take an educated guess. Have guessed about 4 or 5 times now and with a new 'O' ring every time , never had a leak/problem.
Replaced countles oil filters on numerous cars in the past that do not have the plastic filter hosing system and never used a tourque wrench to tighten any of them. Elsewhere on vehicles (where it seems prudent to do so) a tourque wrench is used.
