if you remove the dip stick all the way then remove the cover which goes round the dip stick the oil filter is under this cover if you have got a 111 engine
if you have got the 271 engine it is at the back of the engine near to the bulkhead on the pass side of the engine you will need a 27m spanner or socket to remove it
