Got around to looking at the small oil leak under the starter motor.
The highest point I can see oil is the flange above the torx bold on the top right (and the torx bolt head was covered with a drip of oil before I wiped it off with my finger). It looks like oil from there has spread down and around the bell housing and also forwards along the line of the flange and down.
I'm thinking it looks like the oil is coming from the sump/oil pan gasket in that corner, so it's going to be a new gasket job.
Anyone have any other ideas?
And how difficult is it to drop the sump/oil pan (any issues with the steering/cross member being in the way?)
Also noticed that the bracket (holding the cables) on the left has lost it's torx bolt (you can just see the empty hole hiding behind the steering damper on the left).
