I was concerned to find some oil in an electrical connection just below the air filter housing, so starting pulling things to bits to find the source. Let me explain. A W203 C220CDI 2004 is the car in question.
The large diameter pipe from the front of the air filter box has a smaller diameter breather hose that travels up and connects to the top of the engine near the oil filler cap. Just as this breather hose tees off the larger diameter hose is an electrical plug. This was found to be oily.
Took things to bits and found that the large diameter air pipe as it connects to the MAF in front of the air filter box was all clean and dry. However disconnecting the other end where it connected under the air filter housing is a silvery intake and this had some fresh oil in there. Not exactly loads of the stuff but fresh oil none the less.
As you can perhaps tell I am none too wise as to the technical aspects here. What exactly is the silver intake directly below air filter housing?
I have since cleaned everything up and reconnected all pipes and connections. I guess a picture would have helped you guys but never thought of that at the time.
Obviously I shall keep an eye on this however, should I be concerned; do I need to take the car into a garage sooner rather than later. The car itself is running great I only wanted to check the washer bottle level. Isn't it always the way.
Any advice please. Thanks
