Hi. I think I have a thermostat failure in a W221 S-class, which I believe is the OM642 engine: 2011 350 Bluetec.
The symptoms are that the engine doesn't appear to get up to normal temps, especially worse on very cold days, the temp gauge hovers around 40c but occasionally will drop to zero (an engine restart resets that), and the heating doesn't warm the cabin even on max blower and temps.
From googling, the thermostat could be the culprit and it's nicely located at the front of the engine. However, Mercedes thought it would be funny to use a longer bolt at the back, which is blocked from removal by the fuel rails and other parts of the engine.
Firstly, do those symptoms sound like a thermostat fault, and secondly, are there any guides for replacing the part on that engine without having to take lots of the engine apart first?
I have had a search here and it seems like people have done it, but I haven't seen anything like a step-by-step as to what needs to be removed to make way for the new part.
