unclebuck
- Oct 19, 2016
- CLS 320 /08
Pull the egr valve and give it a good clean if you havent already, you can take the cover off as in my thread, give that a clean and move the valve down and spray an egr cleaner onto it.
For mine i used autoglym engine degreaser and sprayed loads in and moved the valve up and down as there was crud inside the valve stem hole, it took a few back and fores but it cleaned out after a min or so. Wiped it off, sprayed egr clener in there and wiped clean, also the lower vlave, seat and stem were cleaned also.
Wish you could attach a video here, would make for some nice tutorials rather than putting them on a you tube channel.
