One for NW_MERC
KillerHERTZ
Administrator
Staff member
Cambs
SL63 AMG & C220 CDi Estate
A complete W202 electric windows kit & loom.
HERE
£173 for everything you need.
For W202 Mercedes C Class Built 1999, a set of original windows with all four specialized parts. These are the window bars with four electric motors, 4 x door Cable set, cable kit for the interior, switches bar (21082084 10) with decorative panel from the central console model of sports in Carbon optics, switches from the rear doors, and the control unit (26 and 210 21082034 820 35 26) from the doors. The whole system is against the expansion on function, and in order. The components are all W202 C-Class sedan and wagon from 1997 to 2001 with CANBUS fit.
As long as yours isnt a very early W202 with W124 buttons it will work.
I take it all your windows are currently manual. MBenzNL did this mod to his W202 aswell
Oh right, I guess this kit would then be a waste of the front regulators and motors then since you only need the rear bits and the centre console piece to match
IIRC, its not a case of bolting on the rears, you need to replace the lot.
But, the switches are independent arent they, different to the facelift button type which came about later in the later pre-facelift cars. In the later cars the window units were all on one board.
the switches are different, even between facelift 97 model like mine and the 98+ models, all connectors etc are also different!
