Hi all,
Went to look at a W210 E200 Estate today. Visually, it looked sound, very little signs of rust and generally clean. I took it for a test drive and found some strange behaviour with the cruise control/speedtronic.
There's a wand where I guess one can set the maximum speed. Does this need to be set whilst driving at the speed you want to set the limit at?
When I set it at 60MPH, the car would remain at 60MPH, but if I floored it the engine would rev up (to say 4500 RPM) - without change in speed. Is this normal behaviour?
I also found that when not in cruise/speedtronic, and flooring it the engine would need to be revved to 4500RPM before kicking down? Is this normal?
When I stopped at a red light, with my foot on the break, the car would then judder. This seemed intermittent, as it did not happen again after the next restart (but it did occur on 2 separate drives today).
What's the general opinion of the 2L lump on this car? I think it has to do a lot of work to haul that weight? Hows the fuel economy and general performance?
The car has about 80K on the clock, the engine oil looked brown, I popped the coolant expansion tank - but it was too hot - too much pressure with some coolant escaping - this looked clear green so I guess fine.
The engine seemed revvy and responsive - just not sure about the tranny.
Any ideas and opinions greatly appreciated.. (should I spend my 5 and a half grand somewhere else on a different model for instance)
-Phil
-Phil
