jpskiller
Cheers for advice I've got a mate who does electronics, so gonna get him to re-solder OVP relay and see how it goes, will keep people informed..
I'd have thought it'd be the other way round. Ie, adjust the idle using the screw as low as it goes, then adjust the throttle to whatever engine speed you wanted, then adjust the idle speed back to spec.
I know there's a small screw to adjust the idle, I imagine that there is as way of adjusting how much the throttle closes to as well?
Will
I don't think you have a screw as in the 102 variant (side of the throttle body) Adjustment is done as, Ensure the angled plate closes the micro switch to the cold start valve and then screw in or out the bar that goes to the throttle / actuator. Will post a pic tomorrow of what I mean.have you got a diagram that points to this SCREW please.
Just had a look and part no is : 201 540 37 45
top is orange with 2 blade 10a fuses.
Small update,
1) Cleaned throttle body
2) Removed e-mag (shortened Petrol pipe - had to extend to fit e-mag)
4) had OVP Replay Re-Soldered
so far so good, but is intermitent and there is no way to force this problem..i'll see how it goes
does anyone think that the OVP Relay I have is wrong for the car, considereing that when I bought it, it did have a 190e Oil filter on which we changed staright away..
You need to put VIN up to see what options you have ie ASD can influence which OVP relay.
this is definately either the OVP or Idle Speed Control Valve JPS... these are all the usual symptoms..
