Hello
I have problem with my CDI. Well let start with fact it had leaking seal under injectore 2 and it was blowing and coughing like s..t. That was fixed but...
Big cloud of smoke coming from a tailpipe. It was worst before but now its only at higher load when accelerate harder. Well everything runs fine and I did leak off test and injectors are fine. Car runs smooth.
I decided to check for codes and this is what I found:
P0100 Bank 2/5 (Hot Film Mass Air Flow Sensor) Plausibility 1
What do you suggest? Is there any way to check MAS? I dont want to spend money, to buy new one straight away. Can I check voltage or load(resistance) on sensor itself. I checked readings on MAs and it looks like it works fine as the readings change with change of posistion of accelarate pedal.
Is it definite as its MAS or is it air temp sensor? Help - please...
