Morning All,
on my 2009 E320 cdi ive replaced the EGR valve, Turbo actuator, turbo seals, PCV, boost pipe o rings, crank sensor, camshaft sensor, Lambda and batwing as well as given it a full service and am now getting a p0401 code. That's only started since changing the actuator as that the last thing i did. Is there a reset procedure or adaptations etc that i need resetting? Car doesn't seem to run any different, in fact it is much better seeing as my old actuator was goosed. I need to check for boost leaks in the intercooler hoses but other than that, where shoul i be looking?
MAny thanks in advance. apologies for the potential duplication, but most posts on the P0401 code suggest repalcing things that i already have.
