- Feb 22, 2010
- Location
- Stirling, Scotland
- E55 AMG W211, E250 Sport W212, (and some Imps)
That's a bit of a bummer, driving to work and the car stopped showing the C/S option on the dash as well as the current selected gear.
Read the codes and got:
P1856 Selector Lever Position Detection Has Failed
240C No CAN message was received from control unit A80
2226-1 Transmission Control ETC Fault 9
Sounds all too familiar as I did a mates Electronic Selector Module on his SLK only a few months ago with same/similar codes.
Perhaps it's some sort of virus that has been passed onto my car.
Cleared the codes, drove for a but but they returned.
You can't shift from D to R etc. when it has the fault with the engine running.
You can turn the engine off, put it in Park then start and select R from there but once you select D you then can't get R again unless you switch off.
So I've pulled the centre console and ESM out and stuck the one in out of the E55 for now, not showing any errors for now.
Looks like I may need a new ESM.
