P20DD B37 code on ML55
amg55ggg
55 amg
I have a 2003 ML55 with a P20DD B37 code. While stationery the engine will not rev. up more than 4000-4500 revs and vehicle goes into limp mode after few time when the throttle is pressed down with a P20DD B37 code. A quick restart of the engine restores power.
I have changed the accelerator pedal sensor (just in case) but the same thing hapens again.
I fund out that it shouldn't go over 4000 revs to protect the engine while stationary - BUT the question is should i get the code every time it is happening
I have only replaced the sensor - fitted correctly (double checked) plug cleaned with switch cleaner.
It only happens when the car is stationery ( transmission in N or P) - ??? goes into limp mode
Never happened while driving
