Panoramic roof problem
Redfeather19
C220k coupe
THe glass panoramic roof has started to play up on my C230k 2001 - it will only open if given some assistance ie a shove!
Something's not right appreciate any advice for this first time new owner!
i've just had the same problem with the c200 i bought my daughter.
just take the time to clean out the runners. we used wurth light grease in a spray can ,a small flat head screwdriver and had it working as new within 15 minutes.
if the sunroof is opening only it needs assistance, 99% of the time it will just need cleaning.
Thanks for the advice...cleaning sounds the obvious but it doesn't look that dirty and it looks like the inside of a Swiss watch! I might make it worse..
Is it a job after all for a MB dealer?
ours didn't look dirty, just gently open it and clean the runners. keep running the roof back and forth.
BUT, don't force it.
