bruiserdennison
- Oct 11, 2006
I am at my wits end because my 1992 300CE has now been in 3 garages (last one claims to be a specialist) and no one seems to be able to fix it. It originally went into the first garage to have a leaking coolant and cold starting problem looked at. They couldn't sort it so I picked it up and took it to another garage a few days later. During these 3 days, the car started to misfire and then not pull properly until it went above about 3000rpm. When it finally got to the second garage, it would only pull off when cold, otherwise it would start then cut out under load (as soon as you put it into drive). During its two weeks at the second garage, it got to the point where it wouldn't start at all. It has had a compression test which says all is fine, there is a spark on all cylinders and fuel is getting through! (Bizarre!). They suspect that the first garage fiddled irreprably with the fuel distribution system (?). Part of my problem is that I can't find a Merc specialist in Bristol. Found a guy in Shepton Mallet but he wanted £250 just to come and look at the car! I need to sell the vehicle and am prepared to spend up to a grand getting it sorted but no-one seems to know how (surely I could put a new engine in it for that!) Does anyone know a good specialist where I can take it and how I can get it there (not too far from Bristol)? Is it worth going back to the guy in Shepton?
Neil Dennison.
Neil Dennison.
