derin100
On my C124 with the 2.3L M102 it's had an annoying tendency after a decent length run (so that the engine's warm) and then switched off to idle too low/stall when switched back on again.
This quickly resolves once you've got it up and running again.
It's done it for a long time and so isn't related to the new engine I've had put in. It used to do exactly the same before so it must be some issue related to something elsewhere.
When starting from cold it's completely fine.
Any ideas?
Many thanks in advance.
Any ideas?
