Positive post
renault12ts
MB Club Veteran
2005 W215 CL500.
On the W215 CL is there a positive post under the bonnet. I cannot open the boot with the metal key and the battery is disconnected so I want to attach a battery to a post under the bonnet so I can use the fob. I can't see one.
TIA
I'm pretty sure there isn't one... A load of wd40 into the boot lock and some grips on the key should enable you to open it
The key only turned one way and it wouldn't open...I followed the hand book as described. However, with a pair of pliers I was able to turn it (gently) the other way and...it opened. The hand book is wrong, turn it clockwise not anti.
Is that looking from above or crouched down, looking up at the face of the lock?
