Oh bu**er, i am really starting to dislike this car !!!!!!
Ok, for a week everything was fine, then today, on way to work, no heat to windscreen again !!!!!!!.
When i got to work, turned car off, re started it and lo and behold, screen air worked. tried it again, and it worked. Left it for 10 mins, tried again, no air to screen, turned blower up to max, and the flap opened !!!.
I have found, in the car, tiny bits of foam rubber that is blowing out of the vents, its very sticky. What i think is happening is the foam has started to come away from the flap, leaving the glue behind, when the system turns off its default is windscreen vent closed, i think its sticking shut due to the sticky foam.
This would be the reason for the arms splitting as motor is quite powerful. At the moment, only true resolve is to take out heater box, a two day job !!!!!
However, my auto electrician has a small camera on a stalk, like a probe, we are going to stick this down the heater outlet to see what is going on, and if at all possible, try and clear what ever is sticking the flap shut.
wish i had kept my landrover !!!!!!!!
