I have two recent issues:
On start up the engine will turnover but may not start first time, if it does start first time it may be rough for a few seconds and then become a steady idle.
I’m not sure if this is fuel pump related or even the heater plug/relay?
I can be driving along and all of a sudden there is a power loss. I can’t shift up or down on the paddles and the kick down does nothing, the engine won’t rev above 3000 rpm. If I pull over, stop the engine and re-start the problem goes away until the next time which maybe a few minutes later.
I’ve read previous posts about this and the fault ranges from the EGR valve, fuel pump/filter, split pipes or speed sensor. I’m type of the belief that it is a sensor as it seems to be reset when the engine is re-started. There is no engine light.
Thanks for reading any help appreciated.
