W204C350CDI
Had this car a month now, a random issue happens (and it's so quick I don't see the exact message, and nothing stored on the dashboard). This happens when I'm driving away after parking, either from my home, or the office car park, the power steering goes heavy, and a message flashes, and sometimes the radio turns off, car continues just fine, nothing for the rest of the journey. Have driven 500 miles between fault, and then it happened every other day for a week.
I replaced the rear battery (could be 8 years old if it's original), it still happened. Might go for the Aux battery but it read 12.5V when I checked with multi-meter (although I didn't disconnect the positive from the main battery, so not sure if that was an accurate reading).
It may have read "active steering fail" one time, but like I said it flashes for less than a second and I'm usually steering so don't stare at the dashboard.
It's only happened shortly after starting, so either it's because I'm turning the steering wheel a great amount, or something to do with voltages being low and causing an error (might replace the aux battery as it does have some corrosion on the terminal, could be 8 years old if it's never been swapped).
The stop start rarely works too, but I'm going to swap the thermostat because it's reading 70 which is much too low, so that could be inhibiting that side of things.
Feels like everything's going wrong on this car just after buying it!
1. Will these faults be logged in the car if I take it to a garage? Is there a cheaper scanner than STAR systems that will be useful for me?
2. Is this a fault others have encountered?
