Preglow problem
EricU
Hi all
I have a 1999 212Diesel La Strada Campervan, based on a Sprinter body. When the ignition is switched on the preglow light comes on as normal and then goes out briefly when the engine starts up. It then comes on again permanently. Any ideas of why this is happening would be gratefully received please. Thanks
Regards Eric
One or more glow plugs have failed, or the relay/controller has been fried
Preglow
Hi
Thanks for this info. Will check the plugs but where is the relay/controller located so I can look into this also? please.
Regards Eric
i had to change 1 glowplug yesterday.
check this link out, should be able to apply the same theory to your model - using the multimeter is really useful:
Mercedes Diesel Glow Plug Repair
Preglow problem solved
Hi all
Thanks for all replies. The problem is now solved---it was a very poor connection on the relay. All OK now.
Regards Eric
