- Jul 12, 2011
- Location
- Near Salisbury
- E32O CDi Sport, MX5 1.8 Sport, Range Rover 5.0 SC, BMW X1
Of course, it helps to blow the rust off!You guys use pressure washers on your cars ???
No, I use mine to bathe the children. Does a cracking job even if they do moan about it.
Physics dictates that the length of pipe will have no impact on the pressure delivered. Anymore than having a 3m long garden hose is any different to a 30m long hose. Water doesn't really compress so the pressure at the end of the hose will be the same, no matter the length. So go for it!
The only way you would change the pressure is if you fitted a hose with a different diameter (bore). But you won't be doing that so length has no impact.
The one and only time I had a pressure washer used on my E55, the tool using it got too close and removed a small strip of clearcoat. Never used a carwash or a pressure washer since.
There will be losses due to friction.
