Presures : w210 & 18" Rims
proser
Stafford
W210 E320Cdi Estate
What pressures are people running at and please state if saloon or estate ?
Check the inside of your fuel filler flap for the standard pressures and use those.
34/36 front/rear on mine 18amg monoblocks.
Used to run 32 fronts but always looked to bulgy.
Lynall
Isn't that for std fitment ??? which mine aren't :rolleyes:
It's the same sticker for all models of W210, from 15" steels to 18" staggered AMGs!
There are 6 part numbers listed for Sticker on the filler flap of a 210, some must be different.
Main problem i have is that the tyre manufacturers quote vastly different pressures from MB. If you have a problem with your tyre you dont contact MB, you contact the tyre manufacturer.
230K
