Prop shaft bearing questions W164 ML320
Ofpoets
Suffolk UK
ML320 Sport CDi
Hi All. In the process of changing the prop shaft carrier bearing on my 2006 ML320 W164. This shaft doesn'IMG_3868.JPG IMG_3869.JPG t have the usual U couplings but captured bearings as shown in the photo with no apparent bolt to undo. Anyone had any experience of separating this type please ? Also on a curious note. Has anyone removed the prop shaft and driven it without ? I appreciate it's not ideal however this used to be done a lot on the old Freelanders and wondered if there were any issues with driving it without a prop (other than the obvious 2 wheel drive and slight handling difference) Thanks in advance. Photo of coupling
