Hi, I am just fitting the remote roof module from Cabrio-module.de
Everything is fairly easy except the last bit with the relay. - Has anyone fitted one of their kits and can help please so I can get the car back together.
The bit I am stuck on is where it says 'remove the single pink/red cable from fuse 7 going to GB3 to GB4. - I have found the single wire on the fuse and when I follow it to the ring terminal on GB3, I find the ring terminal has 2 wires in it.
Do I swap both wires over from GB3 to GB4 or do I have to cut one wire from the module and just swap the one wire?
Marc
Marc
