KNU7S
- Apr 10, 2006
- Location
- Gloucester
- 1991 R129 500SL Mercedes, 2002 ML270cdi, 2004 Freelander
Looking from some help from you guys if you can
Problem 1 ABS
The ABS light is stuck on my car, all sensors have been replaced and a new ABS pump fitted and the light is still on! its quite annoying really!
Problem 2 Roof
After a long winter i removed the hard top, folding roof worked fine, then it only worked when it wanted to??? It went in and they found a faulty catch? which was replaced, Got the car back and it still only works when it wants to. The light on the switch flashes but nothing. It has never failed to put the roof down it is just temperamental on putting the roof back up?
I was thinking weather there was a problem with the hydraulics, my car is fitted with adaptive damping and the suspension light is now on so is it low on oil??? if so what oil should i top it up with????
Hope some one out there can help!
Problem 1 ABS
Problem 2 Roof
