R129 SL500 cutting out
Watchcame430
Previous 1994 SL500, 2001 W210 E430 and 2003 Designo S500 Current 2005 S211 E270
Hi all,
My 1994 SL500 is cutting out after starting and idling for about 10 minutes or it cuts out right away if I try to drive away when I start her up.
I have replaced the distributor caps and arms.
What should I try next?
Aware I should get diagnostics but I can't drive there and would rather replace bits until I find the answer.
All help gratefully received!
Have you got an EZL ignition unit?
Thank you for the post .. Answer is I am not sure but assume I do having done a quick Google.
Could be the answer .... Will do some more research.
Thanks very much!
Please keep posting any other ideas:)
