rk100
- Sep 2, 2012
- W215 CL65 AMG & W124 E500
Hello all ,my father has an R170 SLK and he is going to replace the cam shaft magnet at the front of the engine. From reviewing on the web it seems that when this is done the starter line (blocker) from it should also be changed to prevent oil going up into the ECU. I have called my local MB and the guy said that on the M111 engines there is no starter line it is just one continue harness and there is no solution to the problem of oil going up (he said the starter line only came in on the later engine model because of this issue - does anyone who if this is correct i.e. a starter line is not fitted to the M111 engine, and if it is not can we get the newer starter line and some way connect this to the old harness? thanks for any help
