Quote:
Originally Posted by
s88
SRS light appears to be on intermitently of late ( I know it says go to the dealer) but the radio and command unit also appears to be cutting out.
Are these items linked in any way, share a fuse etc.
This is with roof up and down, so not sure if the SRS is rollover bar or airbags etc?
many thanks,
S 88
After a few trouble free days the fault appeared again today, constant radio switching off,
command saying "service unavailable".
Then on one occasion a bit of chattering/creaking from over my shoulder!
I therfore suspect the rollover bar as the culprit.
Not sure why it turns off the
command though.
Was out in Lincolnshire the other day and my Nav/map jumped to Sheffield!
\\\\\\\\\\\\ Update May 2011
After some trouble free motoring and discovering I may have been putting the wrong battery on charge! ( Front battery only starts the car apparently)Also some internet searching which advised that windscreen wipers may not work with this problem. Also that the fault may be a SAM unit or EIS module?
The problem re appeared!!
SRS light on red, also orange rollover bar at times, when this appears the airbag light also flashes and having tried the windscreen wipers I can confirm that they dont operate either.
Entire command unit goes off, radio map cd etc. Also a popping/creaking sound behind driver in the boot or rollover bar?
Fault clears after a while or has done and has not been evident when the car was serviced.
