I have the same problem, 2004 SL350, IR is fine, I have bought both RF modules that fit under the dash, but will try to get it on STAR somewhere first to see if there is a more obvious issue, although with the IR working to open the doors its looking like the RF amp - no issues with radio interference or anything like that - I'm in no rush to start stripping out my dash either, I have a copy of WIS, but can't find where the dash disassembly section is
Hi, I have the exact same issue as in this thread, did anyone manage to get a fix?
Symtoms:
- Keyless Entry/Start (KG) NOT Working - 'Key Not Recognised' appears on dashboard
- Remote Locking (RF) NOT Working - Cannot Lock/Unlock car at any distance
- Infrared Locking (IR) is Working, I am able to Lock/Unlock the car if I point the key(s) directly at the IR sensor(s) on the door handles (Where Boot, Doors and Petrol Cap all lock/unlock), which means the PSE pump is working.
So far I have:
- Replaced main battery in boot
- Charged Battery under bonnet (Was more or less already fully charged)
- Replaced batteries in both key fobs
- Checked all fuses (With 12v light tester)
- Tried a couple of steps to sync the keys (Not sure if any of them were correct)
- Connected to STAR, where there was no errors shown, however the '750 CGW. N93 (Central Gateway, Control unit)' was shown as 'NOT PRESENT' ??? (Not sure if this is normal or not)
- Disconnected both batteries (overnight) in the hope a shutdown of the system resolved it
- Unplugged all SAN connectors (Located behind drivers seat) one by one
- Tested all other electrics in the car, everything else seems ok (including alarm).
My first thought is what links the KG and RF systems, are the reliant on each other if so what components do they share? also is it possible to reset the KG and RF system(s)?
Thanks in advance
