R230 Sl500 Engine cut off issues
acetracker2014
Harrow
R230 SL500
Dear Friends,
I have an R230 SL500 which I have had for over 20 years. It has only 43K miles on it and is immaculate but has developed a few issues.
1. Leak in the trunk.
2. Engine cuts off when it's cold first thing when you start it and start driving it. The cut off is for a split second and the car continues going after what can only be described as a hiccup.
3. Door lock not working great. Have to press on remote several times to make it work.
Please can someone recommend an SL specialist that can help with these issues ?
Thank you in advance.
Kind regards.
1 Rear lights sealing gaskets.
2 Don't know.
3 Flat batteries in keyfob?
As for a specialist, Wayne Gates is in your area and has a good reputation on here.
1. "They all do that." A specialist can easily fix it. Here's a thread discussing the whole issue: R230 Boot Seal Leaks | Bodywork
2. Basic diagnostic look up should identify the problem.
3. It'll be a weak battery in the key fob, when did you last change It? (It's easy to do)
Changing the battery in my SL R230 key fob?.
