So my recently acquired 2009 SL500 (cheap but lots of miles and lots of faults) says it's got an ABC malfunction. The Autel fault code reader says it's a fault in the Active Body Control suction restrictor valve. This seems to be attached to the ABC pump and is available for a mere £100 or so. Should I actually just go ahead and change it or does anyone think that the fault code is really hiding another, likely more insidious, problem?
I did buy this car as a project, and so it's turning out to be...
Tim
Tim
