- Nov 1, 2008
- Location
- Bournemouth/Poole Dorset
- W210 E280 x2, w211 E55, W212 E63 biturbo, S204 C180K
R230 SL55's with 19" AMG staggered rims should have 255x35xR19 96Y tyres on the front and 285x30xR19 98Y tyres on the rear.
The most important measurement is the offset (ET)
19" SL55 wheels are Front 8.5j ET30 and the rears are 9.5j ET31
You need to check the S Class wheels you are fitting to see what offset they are. I can't guess as there are different S classes depending on the year.
Look inside the back of the wheels and the ET should be embossed on a spoke along with the Part Number.
The reason those wheels don't fit is they are the wrong ET.
To get over it, you can fit a hubcentric spacer to bring the wheel away from the hub.
To determine what size spacer, use the correct ET for the SL above, front and rear, and take the figure away from the S class ET's front and rear.
(Eg ET 45 minus ET 30 = 15, so you need a 15mm hubcentric spacer and the correct wheelbolt 15mm longer than the ones you have)
Again, make sure you get M14 radius head bolts or the wheels can't be torqued correctly.
You can cross check which S class it came from on this site
Mercedes S Class Alloys (W220) - Alloy Wheels Direct
Its a minefield buying wheels from different models and expecting them to fit straight on
