I didn't think of that too buddy, I've also got a separate hose from the Vessel so that it doesn't get contaminated with tap water, this will no doubt reduce the effect and ultimately waste the water as it would get flushed through with tap water every time you switched over.
I also tested to see if it worked as well using a pump sprayer so I can maintain the amount used on every rinse. I took the nozzle off the end so that it works the same as an open ended hose.
The 5mm will do fine as an outlet hose, cheap enough and 20m will be small enough to wrap up
Hose & Hose Coils
