Next year I'm having sevice done to my car.
Don't drive my car often, service A or B comes every two year.
But I do an oil service every year.
On every two year service I have the brake fluid replaced.
I always used genuine MB bremsflüssigkeit.
For next year I was thinking I'd like to buy a performance type of brakefluid from Motul or Castrol?
Do you recommend these fluids instead of genuine MB, is there any advantage or disadvantage using racing performance brakefluid?
Racing brakefluid is it rated DOT4 or higher?
I know this type of racing fluid has a higher boiling point than MB's own brakefluid.
Brakefluid also absorbs moisture so should be replaced on regular basis on every service.
Are racing brakefluids also sensitive for moisture or not?
Castrol has a Performance fluid.
Do I need minimum 2L to flush and fill complete brake system?
CASTROL 1 L REACT PERFORMANCE DOT 4 BREMSFLÜSSIGKEIT 50043141 | eBay
Entdecken Sie CASTROL 1 L REACT PERFORMANCE DOT 4 BREMSFLÜSSIGKEIT 50043141 in der großen Auswahl bei eBay. Kostenlose Lieferung für viele Artikel!
www.ebay.de
