If you have an original MB aerial, you can get a replacement mask from Stealer for around £12 plus vat (assuming the electric motor in your aerial is okay). Comes with full instruction on the packaging and takes about 5 mins to install. I had already replaced the aerial mask on my C180 twice in the last 8 years. Motor is still fine though.mickl said:anyone know if the aerial is a standard part that you can get from Halfords or it it a Merc specific part? Mine's jammed at half mast..the aerial tha is
Here is what I did.mickl said:motors fine, but the mast is slightly bent therefore won't retract fully. not sure how it was done, must have been driving too fast!
No, mine is in a Hirschmann box with an MB sticker over it!Will said:Sounds interesting - got the box here for the one I bought, and that is showing as £31.62 (it's in a MB box)
http://www.mercedes-benz-parts.co.uk/find/default.aspx?PartNumber=a2028270401
I'd like to know if they are compatible!?!
Will
I was hoping that you can compare if the instruction looks identical or not.Will said:It's ok - I've fitted mine a while back now - just surprised at the ~ 100% difference in price!
BTW, the 1997 W202 mast is compatible with my 1990 W201 for reference
Will
grasmere said:there are other threads on here inc a 'how to' about replacing the mast by pluggers at http://mbclub.co.uk/forums/showthread.php?t=15560&highlight=antenna
You MUST get the CORRECT mast for your car. If its Hirschmann the mast code is on the very top of the mast button, for my 1996 W202 it a code 11 and cost £29.50 from stealers.
