Alfie said:As far as I know all W203's had the rain sensor as standard. I suspect from what you say that your sensor is either faulty or dirty. Give the whole area a good clean, turn the switch to I and cover the sensor with your hand. See what happens
Even if you only had intermittent wipe, the wipers should move constantly on 'I'.
miro said:The rain sensor lens has a violet patch in the older BOSCH types. If the glass area for the sensor is all the same colour then the lens is missing and can not be reftrofitted without a glass change.
miro said:The rain sensor was never standard on the Classic until some time in 2004. From 2000-2001 there was a clip on the glass and the retrofit took no more than 10 minutes.
From 2002-2003 there was only a plastic cover with blank plate and no "lens" for the rain sensor or clip.
From 2003- the sensor clip was the Hella variant which was an all-in-one design and once again a fast retrofit. From 2004- it was standard.
I think we realise that the feature isn't standard, but what I wondered (and am still somewhat confused about) is whether or not the sensor is actually present (either on it's own or combined with the light sensor) and can simply be activated using Star Diagnose.fuzzer said:Ill agree with everything you said except its never been standard on the C class W202 or W203 ever !! maybe on the C32 or C55 , but its always been about £100 quid. Don't believe me? look on the mercedes website and check out the pricelist. £90 for a rain sensor.
IT was i believe part of the comfort pack which was avalible with headlamp wash , rain sensor and folding mirrors .... but never ever standard.
nigel cross said:Reading Miros feedback, does that mean I can retrofit mine as it is a 2001 avantguarde. Is the cost about?? and do the stealers have to enable it?
:bannana: :bannana:
Rory said:I think we realise that the feature isn't standard, but what I wondered (and am still somewhat confused about) is whether or not the sensor is actually present (either on it's own or combined with the light sensor) and can simply be activated using Star Diagnose.
:bannana: :bannana:
Alfie said:I have two C180 W203's. Both are Elegance models both were ordered from new without specific reference to any rain sensor. Both have the rain sensor and the light sensor. Both were ordered in the same county but not from the same dealership. One is a 51 plate pre facelift W203, the other an 05 facelifted W203.
Perhaps the rain sensor is an 'elegance' standard feature.
tonks said:In the back of the service booklet you should have a vehicle data card with a list of 3 digit option codes. If you have code 345 then you have rain sensors.
For the record, my W03 is an elegance and comes with rain sensors (code 345).
A list of option codes can be found on this or similar links
http://www.bekkoame.ne.jp/~mtor/mbcodedsc.html
