Rattling enginge
Aleeshapepper
Liverpool
Mercedes cla 200d 2015
Ive got a rattle on my engine/timing chain. When/if this goes has it got a rod or is it game over?
Don't understand the last bit of the question, could be a typo.
Not sure about your engine if the chain is at the rear but there are videos on tube where the Chain can be replaced without dismantling the engine. The chain tensioner probably can't be replaced this way.However in the video I watched the tensioners were ok it was just the chain that had stretched. There are members on here with a lot more knowledge on this than me who will no doubt come to your rescue but the job needs doing sooner rather than later otherwise catastrophic engine damage can occur.
Do a search one here on the subject as it seems a common problem on some engines.
What's the engine you have is it the OM651 2.1 diesel? What's the mileage , service history etc?
The om651 can suffer from chain issues and it can be replaced without the engine being removed.
Not sure on the engine, its 79k milage and was full serviced about 4 weeks ago. my timing chain goes it a whole new engine or can is it fixable?
You need to give more info i.e. make/model/year engine to get the precise info you need.
