chesterpiglet
- Oct 8, 2008
- Mercedes W211 E280 Cdi Sport Estate
Hi there
I gave my car its Spring clean yesterday & after 4 hours with the doors open & fan on the battery was flat! I charged it overnight & it started this morning but the EPC warning comes on after start up(the ABS & ESP did but don't now). Also the radio is dead- nothing appears on the front panel at all(I have the code but code does not appear when the knob is pressed). I checked fuse number 5 under the seat(it is an estate)& that appears fine, had a look at other wires/connectors around the battery in case I had knocked any but nothing was apparent. Any ideas on both? Does the car need a good long run for the EPC(have I got that right Electronic Power Control???)to go away.
All suggestions gratefully received as always.
Many thanks
Many thanks
