PaulPJ
Hi Chaps, was checking all the lights last weekend and noticed that I only had 1 high intensity rear. Does my W204 only have the one or has a bulb blown? Many thanks Paul
High intensity rear? Do you mean the fog light?
Yeah, there's only a fog light on one side, the right side.
If a bulb was blown, you'd get an error on the dash. If you open up the rear left cluster, you'll see a space for another bulb, but it won't work, that's for LHD cars who have the fog on the left not the right.
Thanks for your help guys. I didn't know if the car would issue a warning or not as my previous car did not warn you if they blew.
High intensity is the correct term "Fog light" is not, the high intensity light or lights are to be used when visibility is significantly reduced be it by fog, rain, snow etc
190 said:Significantly reduced is the important bit. Drivers who put then on when normal rear lights are still clearly visible are a PITA. When they are really needed they are invaluable but many times they are a nuisance and diminish the contrast with brake lights. Some drivers are simply not up to making the judgement.
