Rear self levelling suspension
humbley
Surrey
AMG E63 Estate
My E55 Estate W210 self levelling suspension is not self levelling , i have taken the arm of the anti rollbar and manualy operated it and it seems to go up and down , i suspect it needs setting up adjustment wise , any help here would be great
Regards Humbley
hi mine has self levelling as well check under the bonnet there should be a reservoir on the right hand side that says min max and unbledden ..... it should be on the unbledded mark top up if required ....check to see if there is any misting on the rear shocks as well basically they will go up and down ... but when weight is added they will always appear level .... I have my caravan on the back with nearly 100kg in boot and 85 kg on tow hitch and she looks level when you stand back and give it the once over ......you do get a bit of bounce at that weight but only very slightly .........
Thanks ,Oil level is fine /shocks all good , but when loaded 5 people and luggage its right down at the back wheels almost under the arches , when unloaded rides level with the front , things not right ? , Had a e300td estate before this and that always ran level when loaded
Regards Humbley
It just needs the clamp on the anti-roll bar adjusting to operate the valve a bit earlier.
Thanks for that , will have a go tomorrow and let you know , Should be set from new ?. may have had a new anti rollbar fitted poss ?
Kind Regards Humbley
